I have the side by side monogram fridge..im trying to figure out if the evaporator fan is working correctly.. the fan did come on high when I manually defrosted the freezer, for a couple of hours..then on low the rest of the time..the defrost heater came on and melted the ice away..but when I open the freezer door, the fan doesn't go to high..i left the door open for 3.5 minutes to see if the fan would go on high..it didn't.. I checked the voltage at the board, its at 13,6 input power and output to fan is 13.2...so according to those readings, the fan should be on high..its on low...does that mean the fan is bad...how else can I determine if the fan is working properly..and is this fridge have a multi speed fan for the evaporator..thanks..
