rhornecker
#1 Posted : Thursday, July 5, 2018 7:05:34 PM(UTC)
rhornecker
I have an error code: Upside down F and E
I've replaced the heater element, temperature sensor, control and display board. I have also replaced the inlet and outlet for water, washer door lock, and the outer tub.
Any one come across this type of error code before or any ideas what I may still need to replace, change? Or is this washer a lost cause?
To day I finally figure out the problem. Remove the washer motor rotor cover to check the wires and notice the washer thermistor that I replace at the connector the white wire was loose or fell out of the connector.
I splice the wire and connected back and tape it up so it wouldn't fall out.
How to set control setting / dail on a Frigidaire front loader washing machine (Washer Repair)
by mpiotrzkowski 9/14/2010 4:56:08 AM(UTC)
Kenmoore Front loader Washing machine - making alot of noise went washing (Washer Repair)
by ToddScott 9/9/2010 7:41:50 PM(UTC)
samsung front loader washing machine (Washer Repair)
by black05pony 9/23/2009 5:16:44 PM(UTC)
