I have a glass top GE range. I replaced the two front burners because the outer ring elements did not work most of the time. After replacing them, the smaller burner inner element would not come on, only the outer ring. But I noticed when I turned on the large burner to the right of this one, the inner element then came on! I guess these are both somehow wired together...? Once it came on that first time, then it worked fine until I let it sit for a while. Any ideas for this??
