Hello, I have**Kenmore 596.79243013 fridge and yesterday morning it stopped working.** It's a french door fridge with water/ice dispenser and it's just over 5 years old.** Front panel does not work, it does not display fridge/freezer temperature.** It does not turn on at all.** It's like it's unplugged from the wall except when I open door light inside work.** Is anybody able to help figure out what the problem could be?** How many boards does this fridge have? Is there a fuse I can check?** Logically, if the lights inside turn on that means it gets power, so fuse (if it exists) is not an issue.** It's probably a board.** How do I figure this out? Thanks in advance for any input.
