My dishes are not coming as clean and are not drying at all. When I open machine at any point in cycle, there is no heat. Heating element has resistance. Power for heater comes from 2 pin connector on control board. I have already changed the board and still have no voltage coming out of the connector. There is a thermostat, but that is inline after the board and measured closed with ohmeter. What signals the board to output voltage to the heater circuit?
