When washer is suppose to be agitating it will freewheel instead. I can hold the tub and it will wash fine but if not will just spin around will through the water out of tub. What do I need to do to fix this problem. I have more important things to do other than sit in front of washer and hold the tub still to get clean clothes. Thanks in advance for your help Jon C.
