Hi, My Kitchenaid dryer(KEYE777BWH0) timer is going backwards when we use the minute setting. For example,we set it to dry for 10 minutes, but the timer goes backwards and doesn't shut off the dryer. It dries and works fine otherwise. Any suggestions?
I assume I need a new timer or thermostat.
Thanks Mike
