When I run a normal cycle the washer seems to run out of water during the cycle and I'm looking for guidance on what to try next. Control board was recently replaced and all of the service mode functions work normally (fill level is correct, circulation cycle works correctly, etc.). The dishes do get wet during the cycle but it seems to run dry after about 5 minutes. I have ensured filters are clean and as far as I can tell there's no debris in the sump.
