Hi, My Samsung dryer started making thumping sounds about 6 months ago, and I knew the drum was cracked. Had a small crack, but now advancing beyond a point where I can ignore it, since it is about 6 inches long. The question is, do I just replace the drum only, or what else should I look for? Bad wheel maybe? I was going to buy this, is it correct? Part no: AP5917020 Samsung DC97-17966A Assy Drum WRAPPER;DV9000 - AppliancePartsPros.comThanks!
