Hello, the machine spins too soon, as soon as the drain cycle kicks in it spins full of water and sends the water over the sides. Funny thing is that it only happens before the 1st spin cycle and is fine after the rinse cycle. The rinse cycle works how it is supposed to, it pauses and drains in neutral correctly. It chooses when it malfunctions some days its fine and some days it is not. But like I said no problem during 2nd drain/rinse cycle.
How can I be sure if it is the Timer or Transmission (neutral kit)?
Thanks for any help.
