I’m having an issue with my whirlpool double oven, the other morning the display quit working, oven light would come on, and would beep if you touched any buttons. I reset the breaker and it restarted and worked fine, happened day before last again, I replaced the breaker this time and it restarted.. well today it happened again and will not restart.. I’m not sure where to start the repair process or to buy a new oven.. when you open the door the light turns on when you touch a button it beeps a couple of times.. any idea where to start with parts to replace, without changing all kinds of parts to figure it out.
