Hi , My stated refrigerator model won't dispense cubed or crushed ice. The water dispenser works OK but sometimes drips water in the tray when not used. I removed the front panel. manually opened up the flapper and engaged the dispenser and no ice will dispense. I previously replaced the auger motor and main control board assembly 5303918584 and the ice shute still does not work or the auger motor turns. The ice maker itself works fine. Any idea on this?
