Hello, I have an icemaker that stopped working. The water supply is good as the inline water dispenser works fine. The arm of the ice maker is down as it should be. I have checked the icemaker itself, and there is nothing stuck in it. There is no water at all. I tested the test points via a meter. All were good expect:
L&M timing meter is off: it should be 4400r. Mine is 6800r T&L thermostat is about 75r. I have no ice at all.
Is there anything in this that point to an obvious fault?
I am going to disconnect icemaker tomorrow. Im going to look to see if the hose has frozen. That is all that i can find to look to.
Anything else?
Thanks in advance Ian
