cpsdt1
#1 Posted : Tuesday, February 13, 2018 11:52:16 PM(UTC)
cpsdt1
OUR WHIRLPOOL DUET 4.O WITH SPIN FRESH FRONTLOAD WASHER WFW9150WW02 HAS TERRIBLE VIBRATION. hAVE LEVELED IT, ADDED A PIECE OF 1 INCH DECKING ON TOP OF ORIGINAL FLOOR TO MAKE SURE FLOOR IS STABLE. tHE MACHINE HAS 2 SPRINGS ON TOP OF THE TUB AND ON THE BOTTOM IT HAS 2 SHOCKS ON THE LEFT SIDE ( IF YOU ARE LOOKING AT IT FROM THE FRONT OF MACHINE ) AND 1 SHOCK ON THE RIGHT SIDE. THEY ARE ALL LEAKING OIL FROM THEM SO I AM SURE THEY ARE WORN OUT.
mY QUESTION IS CAN I PUT 4 SHOCKS ON THE MACHINE, THERE ARE PLENTY OF MOUNTING HOLES IN THE OUTER DRUM AND ALSO THE BOTTOM OF THE MACHINE FRAME TO ACCEPT THE SHOCKS. wOULD THIS CAUSE A PROBLEM OR POSSIBLY HELP IT STABILIZE BETTER WHEN SPINNING ?
tHANK YOU
Shock Absorber Replacement (Washer Repair)
by John_huff 1/16/2011 1:00:25 PM(UTC)
vibration/shock absorber replacement (Washer Repair)
by rbutler 9/11/2008 12:18:22 PM(UTC)
