I have a Centennial top loader washer that is having cycling issue: 1. At the start of a cycle the washer agitates while adding water 2. When the timer gets to the END of the cycle it does not shut off. The timer knob does NOT pull in to stop the cycle and the knob continues to go around until it gets to whatever the next cycle is.
I have replaced the timer but still have the same issues.
I bought this washer because it is basic washer and I thought was easy to work on; but this problem has me perplexed.
Any help would be appreciated.
