Our dishwasher stops mid cycle and it can either be the wash or the rinse cycle. What it does is that the blue light (either washing or rinsing) will go off a few seconds then come back on with a little click, and it sounds as if it is resuming the cycle, but then the light goes off again and so on.. it continues to do that until we turn it off. We have tried to stop the whole washing and start all over, but the same thing happens, we have turned off the electricity to reboot, but nothing. We have had 3 people already come out to see it, first they changed the heat element, nothing happened. Then after a few weeks with no use they changed the control panel, it worked well for 3 or 4 cycles and then again the same problem. After that someone came again, we had not used it for a week or two... and when the technician came it worked perfectly fine!... but regretfully after 3 or 4 cycles again the same issue, we stopped using it for a week, and tried again yesterday, but the same issue. Any ideas on what we could check, don't want to call repairs anymore for now so any idea is welcome! I personally get the feeling is something that everyone is overlooking and that it is very simple.. hope you have ideas for us!
