DW fills and pumps out but evidently the motor is not reversing any ideas?
I cannot find any info on your Model Number but if I look up other KUDL01 units none of them have a reversing motor. Perhaps the following will help https://secured.whirlpoo...800643b6d/$FILE/KD01.pdfI would check the motor windings for continuity with a meter. If OK I would check to see if it is getting voltage when it should. If OK then and the motor turns by hand (not jammed) then it is toast. If no voltage Check that the wires have continuity back to the control board. If OK Then probably your control board is toast. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
