Symptoms: Bosch dishwasher won't fill completely. Fills for about 10-15 seconds, then stops filling. Unit then keeps attempting to fill, inlet valve comes on then off, and this cycle of on/off continues indefinitely until resetting the unit. You can hear the audible clicking on/off during this time. The LED that illuminates on the floor to indicate unit is running, alternates between on and off every second or so during this failure.
Tried manually filling the dishwasher with water, and it does not run. It drains fine and seems to drain completely after resetting the cycle.
Would like to repair myself, looking for ideas on what to replace and in what order.
Thanks,
Mike
