Hi, I have a Kenmore dryer 110.70022011 that is not lighting all the time. wondering what I should check?
I replaced the thermal fuse as it was not showing continuity. It will now light the burner intermittently. Sometimes it will light and stay burning for 15 minutes other times it will light then immediately go out. Other times the ingnigtor will not even glow....
parts replaced so far....
thermal switch (fuse) ignitor
Should I look at the coils next?
