AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't start after replacing timer, fuses
Hello, My dryer wouldn't start unless the timer was in certain parts of the cycle, and the dryer was turning off too soon. I could start it again by turning the timer backwards and pushing the start button. Eventually the dryer wouldn't start at all. As a test, I temporarily bypassed the timer. The dryer ran, but I left it running too long and blew a couple of fuses in it... I installed a refurbished timer and checked that all the wire colors matched the labels on the timer (2 photos attached). The timer motor spins, and the timer seems to reset the push-to-start relay when the timer hits the "off" position, but the dryer isn't starting. I replaced the following in addition to the timer: * thermal cutoff (red and RW wires -- at top of intake vent) * cycling thermostat (red and RW wires -- at bottom of exhaust vent) * thermal fuse (blue wires -- at bottom of exhaust vent) I checked the following, and they seem to be operational: * 240V * door switch (light turns off when I depress switch) * temperature selector (resistance matched specs on wiring diagram) * push-to-start relay (connection between blue wires closes when button is pushed) * high-limit thermostat (red and BW wires -- next to heater -- closed at room temperature) * drive motor (I didn't run it, but it spins okay by hand, and I verified that there is low resistanceat the two places circled in the 3rd attached photo) Any suggestions? Thank you! Alan alan.nc attached the following image(s):
Dryer Repair
