It'sa Mea, Mario!
#1 Posted : Friday, February 2, 2018 12:16:34 PM(UTC)
It'sa Mea, Mario!
Hello!
Have a Whirlpool 'fridge that have the following replaced already:
1. Cold Control
2. Defrost Timer
3. Defrost Thermostat
Fridge won't stay running. When it does run it will get cold like it should for a while but then will stop working after 4-5 days. I have spun the defrost thermostat and had it 'click' a couple of times but didn't kick on. Have turned off the unit at the Cold Control but didn't kick on. Have unplugged then plugged (which it would start running a short time after) in but didn't kick on.
With parts replaced mentioned, freezer fan inside is not spinning as well as the fan at the back bottom near the compressor with power on.
The fan at the back bottom near the compressor spins freely when moved as well as the freezer fan.
I can make ice. I can get water when the unit first starts running but then i can't once it reaches temperature.
all this maybe overkill but i am trying to list all the things that i have been running across...
I was attempting the repair but keep falling up short. Was thinking to ask for some help... so what do you say Luigi? Can ya help out your old pal Mario?
thanks in advance (tia)
Whirlpool Refrigerator ED22PQXFN00, MFG 02-99
