Our dishwasher does not appear to be heating the water while it is washing however it will heat up during the drying cycle. I bought a heating element and when it arrived I wrangled the dishwasher from under the counter top and installed it but it did not solve the problem. I ordered the high limit thermostat and then decided to check the thermostat on the washer since I did not stuff her back in under the counter. The ohms test shows continuity so I ordered that part unnecessarily. I'm at a loss as to what to check next, can someone advise me? Thanks
