My dishwasher only leaks water on the first fill. It fills up with water and when the pump starts water drips from the front bottom of the door. The float is working properly, cutting out at the same place on all cycles. It dose not stick on the first fill. This only happens on the first fill or cycle. It dose not leak during the rest of the wash.
