We had no water to the ice maker but had water on door. Replaced the water valve assy. And everything worked fine for about a week. Now we have no water on door or ice maker. Water is leaking from the filter case inside. We changed the filter again and replaced the o ring inside the filter cover. Still leaking when you use the door water button and still no ice. So we unplugged the refrigerator to see if there was ice frozen in the lines, still leaking. I’m at a loss as to where the problem is.
