eligross
#1 Posted : Wednesday, January 17, 2018 7:47:02 PM(UTC)
eligross
I had to replace a valve, following instructions i just couldn't remove the top of the oven thu to the SPARK ELECTRODE that wouldn't detach from top, do anybody knows how to remove the top of this gas range completely?
(how to remove the SPARK ELECTRODE)
thanks
GE Gas Range Faulty Temp Readings and Slow to Heat (Oven Repair (including Ranges and Cooktops))
by yotimbo 2/9/2016 7:46:12 PM(UTC)
GE Gas range:XL44 - How to open sealed unit (Oven Repair (including Ranges and Cooktops))
by Jim Silvius 10/31/2012 12:02:04 PM(UTC)
Auto igniter not working on GE gas range (Oven Repair (including Ranges and Cooktops))
by saiprasad 6/28/2012 4:36:35 PM(UTC)
GE gas range (slide in) oven repair (Oven Repair (including Ranges and Cooktops))
by catinthehat 12/26/2011 10:13:16 AM(UTC)
GE Gas Range not holding temp (Oven Repair (including Ranges and Cooktops))
by Chance69 8/12/2011 9:24:40 AM(UTC)
GE Gas Range not holding temperature (Oven Repair (including Ranges and Cooktops))
by dfriend 2/23/2010 8:11:35 AM(UTC)
Burned insulation on igniter wires - GE gas range (Oven Repair (including Ranges and Cooktops))
by pbillow 1/31/2010 11:17:12 AM(UTC)
Maytage Gas Range - 2 Left Burners Won't Ignite - Have Spark (Oven Repair (including Ranges and Cooktops))
by boiler7904 9/28/2009 4:34:11 PM(UTC)
GE Gas Range Broiler will not shut off (Oven Repair (including Ranges and Cooktops))
by korybw 8/14/2009 8:21:55 AM(UTC)
Ge Gas Range Popped Circuit Breaker (Oven Repair (including Ranges and Cooktops))
by SFCHAMP97 6/5/2009 5:46:40 PM(UTC)
GE Gas Range diagnose ignite problem (Oven Repair (including Ranges and Cooktops))
by jonhunt 4/28/2009 9:37:12 AM(UTC)
by williamhaid 4/26/2009 2:10:48 PM(UTC)
GE gas range oven (Oven Repair (including Ranges and Cooktops))
by gdpifer 4/26/2009 7:53:06 AM(UTC)
GE gas range bake ingniter won't light (Oven Repair (including Ranges and Cooktops))
by petewh 3/26/2009 1:38:55 PM(UTC)
ge gas range (Oven Repair (including Ranges and Cooktops))
by cstefan 3/1/2009 1:40:36 PM(UTC)
