This has been a great dishwasher, best one we've ever owned. But suddenly, the spray arms are not turning. None of them. Water is sort of burbling up out of the bottom spray arm, but not enough to make the arm spin. The arm spins freely manually. Plus, the unit is making a sort of loud humming noise. Does this sound like the circulation pump? Could it be the impeller? If so, does this model support replacing the impeller separate from the pump assembly?
