ingram216
#1 Posted : Wednesday, November 4, 2009 12:18:59 PM(UTC)
ingram216
I have replaced the hi limit thermo, heating element, thermal cutoff, thermal fuse, cycling thermo and dryer still does not heat. there is one thermostat with four terminals not listed on the parts list and it it located at the bottom of the dryer oppisite of the heating element. Need Ideas!!
#2 Posted : Wednesday, November 4, 2009 3:27:33 PM(UTC)
Have you checked for 240 VAC at the wall outlet for the dryer? You also might want to check the power cord connection to the dryer.
ingram216
#3 Posted : Thursday, November 5, 2009 5:47:37 AM(UTC)
ingram216
The dryer runs and runs well, it just will not heat
#4 Posted : Thursday, November 5, 2009 2:38:44 PM(UTC)
The motor needs 120 VAC only while the heating element needs 240 VAC. If one of two power legs is missing (bad breaker, broken wire, loose connection etc) the dryer would run without heat.
P.S. I definitely read your first post and noticed that the dryer runs well.
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
