I’ve got a Frigidaire double oven and only the glass stove top will work. Clock never turns on and the heat setting on the burners work for maybe 2 mins then first burner pops up F5 on screen second burner 00 third burner f5 and fourth burner 00. If I turn the burners off then back on they’ll work but the display never changes and the clock/display never works for the oven. Any help will be greatly appreciated.
