Hello - I have a Jennair SVD48600W range and the OFF button on the keypad is not working. I have narrowed it down to a fault in the ribbon cable connecting the oven control panel and the keypad. Unfortunately, we do not get the keypad panel in white anymore, due to which I have to fix the cable in the ribbon cable. The ribbon cable has about 16 wires. How do I figure out which is the one for the OFF button? I would to 'jump' it with a wire and a solder. Thanks !!
