bnoreszko
#1 Posted : Wednesday, December 27, 2017 6:19:23 AM(UTC)
bnoreszko
Recently, I was having issues with my washer. It was showing a decimal point in the "Time Remaining". It would count down in seconds and then restart without starting a wash cycle.
Through some research, I found out the user control panel was most likely to blame. I just ordered a new one and installed it yesterday. The problem is I cannot find anywhere online to program the new control board for my model. The control board gives me programs numbers 1-6, but I'm not sure which to choose. What program number should I use for this model?
I selected a number just to test and see if the new control board solved the previous issue I was having. The decimal points are definitely gone. I'm guessing the program number is not correct though, because when I try to start a cycle, a little water came into the machine, the drum rotated two or three times and then it stopped.
Any suggestions?
