I have a Kenmore Commercial washer model 110.27122310 that when it starts it fills up with water a little bit and then starts to cycle. If I pause it and then hit start it will fill up with water like it should. I tried recalibrating that did not work. I replaced the main control which has the pressure switch built into it and it still hasn't worked to resolve the problem. It happens on all temperature settings and load settings. Any help would be appreciated
