Have bottom freezer ice maker. Makes normal cubes but tray gets water in it and becomes solid block. When looking at it water fills tray and overfills and water pours out of back of unit. Research says faulty water inlet valve can cause a leak. This is far from a leak water pours when overflowing. Can this als be a bad water inlet valve. Thanks for your time
