The repair man took the dryer apart, took the money to get the part and never came back 😩. I was able to get and replace the drum pulley myself, I reattached the door but there’s a cluster of wires in the door, the green and yellow wire (I assume is the grounding wire) is now just hanging. I have no idea where to connect it to properly ground it. Does anyone know?!?!
