Washer fills and drains fine. After fill the wash light come on but no agitation occurs. I searched for possible causes and have done the following: 1) Reset the control board by pausing in wash cycle, then unplug for 1 minute, then plug in and open and close lid rapidly for 12 seconds. Move to spin - nothing happens. 2) Remove front panel and check for blinking LED. In pause it blinked 1 sec on 1 sec off. In wash there was no light. 3) Checked thermal fuse for continuity. Fuse had 100% continuity. Prior tennant had left a large blanket in the machine. Please recommend a next step. Thanks.
