The fridge door remains about 1/8" open at the bottom 6" on the door handle side. I think the gasket is not able to hold the door in closed position all the way around. I just purchased Part #2188450A from APPliance PartsPros. The Kenmore part # is listed as 986702 with substitute number TPCS42. Neither part is available from either Sears or Kenmore so I purchased this one that is listed as cross match.
If you have ever replaced this gasket or know how to do it please give me step by step direction with video if possible. It appears that the current gasket is held to the door with and what appears to be a galvananized steel strip on all four sides and several screws.
Thanks for your help.
