Stevevo
#1 Posted : Wednesday, November 4, 2009 5:49:07 AM(UTC)
Stevevo
The stove top works but the bake and broiler don't. It will click but never heats. Is this the Timer/Controller that it bad? The element ohms out good on both of them but no output of power to them.
#2 Posted : Thursday, November 5, 2009 3:53:51 AM(UTC)
Was thanked: 10 time(s) in 10 post(s)
Here is a wiring diagram for a FEF336ECG
http://manuals.frigidaire.com/p...ingfield/316441458en.pdf
Does sound like the control board is gone.
To confirm this you will have to measure the voltages at the board.
I would also check the oven sensor for the proper resistance.
Frigidaire range won't bake (Oven Repair (including Ranges and Cooktops))
by lenjack 6/17/2018 2:25:06 PM(UTC)
Removing Cooktop on a Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by smwilliams 5/12/2015 8:57:01 AM(UTC)
Frigidaire range - No Display (Oven Repair (including Ranges and Cooktops))
by hambob64 1/19/2015 5:59:15 PM(UTC)
Frigidaire range oven problem... (Oven Repair (including Ranges and Cooktops))
by Cr00zng 4/22/2013 7:58:08 AM(UTC)
Frigidaire Range,main Panel. (Oven Repair (including Ranges and Cooktops))
by bthdlm 3/4/2013 9:57:05 AM(UTC)
Frigidaire Range FEF365ASG won't bake or heat oven chamber (Oven Repair (including Ranges and Cooktops))
by lostsole1976 1/7/2013 11:03:19 AM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
Latch Door Motor for Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by hecman 4/17/2012 11:52:02 AM(UTC)
RCI-75-62 Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by keysrose 3/28/2012 1:40:39 PM(UTC)
Frigidaire Range Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by Bruce7799 12/15/2011 5:11:43 PM(UTC)
Broken frigidaire range glass top and having trouble with model number (Oven Repair (including Ranges and Cooktops))
by damuddog 8/23/2011 3:50:24 PM(UTC)
by bigg2367 6/22/2011 12:19:08 PM(UTC)
Frigidaire Range Oven Problem (Oven Repair (including Ranges and Cooktops))
by bgarrett6 1/21/2011 4:59:04 PM(UTC)
Dim Display on Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by stevest 12/3/2010 4:08:55 AM(UTC)
Frigidaire Range Stopped working (Oven Repair (including Ranges and Cooktops))
by callii 11/4/2010 5:17:55 PM(UTC)
