My washer is spinning but sounds loud and like it’s geinding it keeps giving the UE code and then tries to rebalance. I’m trying to figure out if I need a whole new clutch or if I can just replace the shift actuator. Not sure how to tell which one I need to replace. When I turned the washer over the actuator looked a little cracked.
