Oven Goes Into Clean Mode By Itself. Have To Turn Off Breaker To Reset. Oven Will Beep Then F3 E2 Cln Cool Will Be Displayed. Just Changed Out Board With Another Used Board. Problem Still Occurs With Both Boards. Problem Seems Like It Usually Only Happens When Baking, But It Did Turn On One Time When Everything Was Off With Old Board.
