jeffso
#1 Posted : Wednesday, November 4, 2009 4:54:02 AM(UTC)
jeffso
if someone has a wiring diagram? I'm having same problem with drain solenoid melting. Its getting 120v for 10 sec. Is the timer bad or is there a nother switch? Ge dishwasher hda2000g00ww. thanks
#2 Posted : Wednesday, November 4, 2009 5:06:55 AM(UTC)
Replacement parts for GE HDA2000G00WW | AppliancePartsPros.com
GE likes to keep this info secret so I do not have a wiring diagram.
Perhaps someone else can supply it.
This is how it should work. The problem is the timer contacts get pitted and stick closed every once in a while overheating the solenoid
As far as I know there is not another switch.
I would replace both the solenoid and the timer.
GE range replacing a infinite switch but need the wiring diagram (Oven Repair (including Ranges and Cooktops))
by jlsalazar101 1/24/2024 2:49:12 PM(UTC)
Need Old Admiral Wiring Diagram (Washer Repair)
by jkuly 1/15/2024 6:09:44 PM(UTC)
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Refrigerator Wiring Diagram (Refrigerator & Freezer Repair)
by Prairie Traveler 11/10/2022 9:39:05 PM(UTC)
Sams RF28K9380SR/AA door connector wiring diagram (Refrigerator & Freezer Repair)
by Guest 9/17/2022 4:09:41 PM(UTC)
Whirlpool LAE550W1 wiring diagram (Dryer Repair)
by z001010racs0 6/29/2022 10:42:02 AM(UTC)
Wiring Diagram for Whirlpool Control Board 2252195 / 2304006 on KSRT25CRM - Help? (Refrigerator & Freezer Repair)
by kpfeif 4/18/2022 10:26:51 AM(UTC)
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 10/19/2021 12:38:16 PM(UTC)
no wiring diagram for drain pump installation--HELP (Washer Repair)
by TanyaDA 3/17/2021 5:16:46 AM(UTC)
Wiring diagram for W10410892 (Dryer Repair)
by sra2786 4/12/2020 4:55:28 AM(UTC)
Wiring diagram needed Tappan Wall oven (Oven Repair (including Ranges and Cooktops))
by Sandman038 2/2/2020 12:54:48 PM(UTC)
Missing GE Wiring Diagram (Refrigerator & Freezer Repair)
by thumbrfg 8/21/2019 6:05:13 AM(UTC)
missing wiring diagram for WE17x10010 (Dryer Repair)
by ravencc 8/8/2018 2:37:53 PM(UTC)
Reqest wiring diagram for KitchenAid Side-by-Side refrigerator model KSRG25FKSS05 (Refrigerator & Freezer Repair)
by thegreatscott 3/12/2018 5:01:08 PM(UTC)
Where can I find dishwasher wiring diagram? (Dishwasher Repair)
by Nifty 2/18/2018 9:24:52 PM(UTC)
