ndozois
#1 Posted : Wednesday, November 8, 2017 7:32:00 AM(UTC)
ndozois
YIKES !
Ordered Coupler Kit.(Wasn't spinning)Found 1 Coupler broken and Grommet very weak.
Replaced-FIXED thank you...
However--All cycles working EXCEPT no water at spin cycle(RINSE)cycle doesn't dispense water ....
OK I'm LOST now.....
HELP !!!!
ThatGuy
#2 Posted : Wednesday, November 8, 2017 2:05:01 PM(UTC)
ThatGuy
Groups: Expert
Most rinse cycles are cold water. Have you checked to see if you are getting any cold water?
If not you can also test for voltage at the cold water valve. It should be getting 120 volts AC when the washer is filling with rinse water.
Whirlpool 285805 Water Inlet Valve - AppliancePartsPros.com
UserPostedImage
ndozois
#3 Posted : Wednesday, November 8, 2017 2:54:59 PM(UTC)
ndozois
Amazing things Happen sometimes..
Thank you for your quick response.
Early I checked the cold water supply. Apparently forgetting to open from last nights repair of the coupler kit.
All is well and Ill keep your knowledge handy for the next bout with this washer.....
Thank you again
Nancy
