Hi, Our Whirlpool Model no GI5SVAXVL01 failed last night. This morning we found the refrigerator is warm, the ice from the ice dispenser were melting, freezer was warming up.
The internal light is working; however, on the back of unit the compressor is not running, fan above the drain tray is not running. In fact, I confirmed with the non-contact voltage tester that electricity goes from the outlet to the main board & internal light unit but not to the compressor or fan mentioned above. There is no light on the dispenser control monitor on the front, however, if you touch one of the buttons, blue light display and then disappear.
Capacitor and compressor appear to be fine by multi-meter continuity test.
What should I check next before I order a part?
Thanks!
