muddyninja1
#1 Posted : Saturday, October 21, 2017 1:37:09 PM(UTC)
muddyninja1
Have a problem and I need some help. I have a Maytag Centennial washer. Problem started with dripping wet clothes when wash cycle was completed. Then a few days later when you hit the start button the "sensing" light would come on, lock would click, lock light would come on, tub would move 1-2 inches, motor him for a second, then another click, lock light would start to blink or flash. It would stay like this. The only way to remove the clothes was to unplug washer, sit for 30 seconds, plug it back in, when the lock light would come on press and hold start for 3 seconds and it would unlock.
I did some research and found or thought the "shift actuator" was bad. Ordered a new one, replaced it. Re-calibrated the machine,.....same problem. It will not work. So, after more research I am thinking that the lock switch assembly is bad. Does this sound right? I'm not an appliance repair guy, I can replace parts, but I'm no technician. I need some guidance and knowledge thrown in here. Help!
maytag centennial washer (Washer Repair)
by arodriguez01 2/6/2018 8:29:06 AM(UTC)
maytag centennial washer low fill (Washer Repair)
by redjada 9/3/2017 9:01:47 AM(UTC)
Maytag Centennial Washer doesn't Agitate (Washer Repair)
by hosehead78 4/16/2017 5:46:30 PM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
Maytag centennial washer drum sits too low (Washer Repair)
by jansmeall 12/8/2016 11:59:20 AM(UTC)
maytag centennial washer wont goo into spin cycle (Washer Repair)
by shennondw 8/9/2016 6:20:41 PM(UTC)
Maytag Centennial Washer (Washer Repair)
by fivermillions 2/21/2016 5:23:23 AM(UTC)
Maytag Centennial washer stops after filling (Washer Repair)
by dfrancey 5/5/2015 7:41:28 AM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
by maytagQuestion 3/2/2015 1:11:52 PM(UTC)
by Scotty1231 10/5/2014 7:45:25 AM(UTC)
Maytag Centennial Washer Transmission??? (Washer Repair)
by Fixit-teer 4/13/2014 6:58:06 PM(UTC)
by ShadeTree231 3/23/2014 5:02:51 PM(UTC)
maytag centennial washer, loud spinning sounds (Washer Repair)
by korean1 11/16/2013 6:53:18 PM(UTC)
by venmsss 10/1/2013 8:15:58 AM(UTC)
