daviddep1
#1 Posted : Tuesday, October 3, 2017 11:59:04 AM(UTC)
daviddep1
Bought Used Gas Range.
Oven will not light. No gas flow. Igniter Glows RED Hot.
So Far:
1) Swapped Broiler Igniter for Oven one... Same Result. Broiler will Light, No Oven.
2) Purchased used control Board on ********. Same Result.
3) Purchased used Gas Safty Valve on ********. Same Result.
Out of ideas...
I did meter the safty valve. The Boiler terminals did have a higher voltage than the Oven terminals. i dont have exact. but Oven was under 3V, 2.X.. The Boiler Terminals were over 3V. 3.6 I think..
Did not meter the replacement valve, as the oven wont' light with either one..
Appliance repair coming Friday. I'm not super handy nor experience with repairs.
*Appliance shop parts guy thought that based on symptoms, most likely the control board; if you rule out Ignitors,and the broiler works, gas flows for both Oven/Broiler from same Safty Valve...
