I have an LG WT1101CW washer. It started throwing UE unbalanced codes, when it does this it adds more time to the wash and restarts, this can go on for hours. It happens more with full or small loads, we have been told to "add some towels to small loads" but that doesn't help. Sometimes, most times, it won't even finish a spin cycle when it's EMPTY. I was told that the control board was the most likely problem, I replaced it and it made no difference. I was told the suspension rods were a possibility, they seem intact and compress and rebound all about the same. Next was the balance ring, it sounds like it has fluid in it, but I didn't remove it to test it. Any help?
