Hello All,
I purchased a pre-owned Viking range that is quite a bit old. I believe the model number is VGIC305. When I installed the range there was quite a bit of heat coming out of the oven door from the top right, as well as from the backsplash. I've since changed the oven door gasket and hinges, and while it has significantly improved, there is still some heat coming out of the top right of the oven door when pre-heating. Are there any other adjustments I can make to the oven door/hinges to resolve this?
Thank you all for your input.
