Trying to repair the spider/broken front tub and was able to take it apart without much trouble. Does anyone know the factory torque spec for the 19mm bolt that holds everything in place while putting those back together? Online videos show just hand tightening. During disassembly had to use a much bigger torque wrench to loosen it than the one used in the video. Since it appears to be a critical part to keep moving parts in place so don't want to rely on feel that could lead to under/over tightening. Does it matter at all? Thanks!
