I had problems with ice maker not working and water leaking at dispenser door. Called Repair Service and they replaced the water valve. Repairman installed the valve with my help. He seemed unsure how to replace the valve. The tubing lines had special connectors that he didn't know how to release. We finally got the vale installed and the ice maker started working and the leaking at the dispenser stopped. A couple days later, I noticed water in the drawer compartment and water leaking on to the floor. Evidently the tubing connecting to the valve are leaking. I called the repairman a week ago and have heard nothing from him. Can I order the tubing connectors for the lines connecting to the valve? I guess I will have to repair the problem myself. Nobody seems to want to work on Samsung appliances.
