I'm replacing the water pressure switch due to water level too high [ at middle of door window ] regardless of size of load. in diagnostics memory shows a F9E1 Water valve does shut off but stays on too long. My question is: is water supposed to come up the tube going to the pressure switch? Also The main controller is brand new. Thanks.
