lothian.mcadam
#1 Posted : Thursday, August 24, 2017 4:16:21 PM(UTC)
lothian.mcadam
GE Wine Chiller
model: ZDW24ARBB(ABB)
The evaporator coil plate inside our wine chiller is covered in a thick layer of ice. When I turn the thermostat to "off" the unit does not switch off, so I unplugged the chiller. This problem is recent, as far as I know.
The problem with this chiller seems fairly specific, but I find very little t'shooting information here or other appliance repair forums. I suspect the thermostat is faulty; however, the cost for this part exceeds $250, which is untenable.
My first question is, how do I determine the EXACT cause of the problem I described.
My second question is, presuming the thermostat is faulty, rather than replacing this component, can it be repaired; and, if so, how does one go about the process?
My third question is, presuming the thermostat is faulty and cannot be repaired, is it reasonable to install the thermostat spec'd for a similar model wine chiller?
lothian.mcadam attached the following image(s):
You cannot view/download attachments. Try to login or register.
