I have a Frigidaire FGF366ECA and the time/temp display only shows the first and last number. If I push against the panel the other numbers show up so I can still set the temp when I want to bake. Before I buy a new panel I was wondering if there was something else I can try? It works fine otherwise.
Thanks in advance
